EInvalidOP raised by ... each second
jerry0815
With a Skystar 2 and the current DVBViewer Pro 3.2.6.80 I have the problem described above. The full errormessage written every one or two seconds to DVBViewer.log is
08.05.2006 16:40:55 EInvalidOp raised by instance tmrStatus of class TTimer at 00402EFB:Ungültige Gleitkommaoperation
One side effect is, that it's almost impossible to enter settings in the Options window - whenever selecting a list box, immediately the focus is lost (I suppose due to this error occuring), and so its not possible to actually do a selection.
TV display is o.k., however EPG does not work at all and I did also not try out the recorder (I'm using my original Technisat - Viewer, which is still installed and works perfectly).
Also, when installing the DVBViewer Pro, it was not possible to scan channels (only dvb-c cable was offered, no satellites), after scanning with the TranEdit Plugin, exporting channel list there and re-importing in DVBViewer it finally worked.
support.zip is attached.
