thejaff Posted May 9, 2006 Posted May 9, 2006 I am a Fire-Dtv-s user, and my setup includes a Stab HH90 motor... I am looking at DVBViewer and drooling in comparison to MyOthre sat viewing program. I am ready to buy, but looking through the manual, I didn't see any place to enter in positions for each sat... Is that something that is supported in DVBViewer? If so, I can't buy fast enough.. if not, well, I guess its not for me then.. at least not at this time. Quote
Derrick Posted May 9, 2006 Posted May 9, 2006 The answer is no. No support for diseqc 1.2 with DVBViewer. This is for historical reasons cos the specs. for the SS2 doesn't allow high current for the motor. Quote
thejaff Posted May 9, 2006 Author Posted May 9, 2006 That is unfortunately what it looked like in the manual.. I really don't know enough about this to know if it would be possible, but.. is there any way it could be implemented via plugins? Like I say, I am not familiar enough with the way your program accomplishes what it does.. I am just envisioning that depending on the sat selected, the plugin would send a command to direct the motor to a new position. And thank you for such a quick reply... Quote
