janfin Posted May 10, 2006 Posted May 10, 2006 Is TT-connect C-1200 (USB-box) supported by DVBViewer? Or is there any other usb connected dvb-c, which I could think about? Quote
Engelbert Posted May 11, 2006 Posted May 11, 2006 (edited) Aus deren Datenblatt (2004) ist nicht zu entnehmen, daß USB2 unterstützt wird (nicht USB2 kompatibel). BDA-Treiber? Würde ich von abraten. Wofür soll das USB-Gerät denn sein? Als Kabel-Version kann man es ja nur zuhause betreiben. PC / Notebook? Edited May 11, 2006 by Engelbert Quote
janfin Posted May 11, 2006 Author Posted May 11, 2006 Aus deren Datenblatt (2004) ist nicht zu entnehmen, daß USB2 unterstützt wird (nicht USB2 kompatibel). BDA-Treiber? Würde ich von abraten. Wofür soll das USB-Gerät denn sein? Als Kabel-Version kann man es ja nur zuhause betreiben. PC / Notebook? <{POST_SNAPBACK}> Yes, those have BDA-drivers. Reason for USB is that I have VIA EPIA M10000 mainboard and in that I can't define separate IRQ for DVB-card and it don't work at all. When I'm trying to tune, computer reboots. Quote
Engelbert Posted May 11, 2006 Posted May 11, 2006 Please: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
janfin Posted May 11, 2006 Author Posted May 11, 2006 Please: http://www.DVBViewer.com/forum/index.php?showtopic=2210 <{POST_SNAPBACK}> Here is supporttool.zip support.zip Quote
Engelbert Posted May 12, 2006 Posted May 12, 2006 You can make update DVBViewer version 3.2.6 with PRObeta 3.4.9.261. Please follow the Readme.PDF carefully! Quote
