W-O-S (WakeOn On Serial)
Foxmul
Hi
I'm using the technisat remote, and I'd like to know that it will be a function to PowerOn the PC by using the remore..
Regards
With this remote control and DVBViewer PRO you can do this.
I can start my PC via remote with this control and i use it for DVBViewer.
This works if the IR device can trigger any of the Wake ON function in the BIOS.
So first check iout which wake on functions the BIOS has. Then choose an appropriate IR device that is connected to that port.
Then you can trian the software to shut down/restart the computer with the standby button on the remote.
