no disecq switching with my Twinhan PCI card
frazer
Hello,
I can't get the diseqc switching to work with my Twinhan card in DVBViewer, even though it works with all the other DVB software I have tried. I am using the latest Pro version with the Twinhan BDA drivers and can't find any channels on any other satellite than LNB A/A; I have also tried the latest beta version with no more success.
Are there any tips anyone knows that might get it going, or is there some setting I am missing; at the moment I just have the correct satellites set to the correct LNBs in the Channel Edit settings.
Thanks for any help,
Frazer
What is your diseqc configuration? (multiswitch, 4/1, simple..)
Sorry, should have included that it's a 4X1 Pansat Diseqc 1.0 switch.
Thanks for the reply,
Frazer
..and without BDA? I can't help you cos I don't have this hardware.
I tried it with the non-BDA drivers, and it still doesn't work, though again it does work with other software (myTheatre/altDVB).
Thanks again for the replies,
Frazer
