Problems with DVB Viewer
iftiml
I have installed DVBViewer demo but ....
I can see picture and sound only 5 to 10 seconds then picture freezes, no sound and picture appears every 5-10 seconds and then dissappears , also computer work wery slow (like slide show), no sound at all...
When i close and open DVBViewer same situation again (pic & sound 5-10 sec... and then slide show) :)
I have tryed every combination of renders .... same ....
I have Duron 1.1 with Abit Siluro 64mb Card, 192 mb ram ....
On tv4pc works perfectly ...
Can somebody help me what to do?
which mpg2 filters do you have installed? If you havent anyone try elecard. And have a look at the renderer. Use 4.22
Abit Siluro cards come with a software DVD player, which installes the intervideo mpeg decoder, which doesn't work with the DVBViewer - picture freezes, I experienced it too.
Install the decoder package from Elecard and/or look for ivivideo.ax in c:\program files\ABIT\Common\Bin and try to unregister this filter with RegSvr32.exe /u. If you don't know how to do this, post again, and I'll give further instructions.
CU
Griga
I have elecard codecs installed and not working...
I have looked for ivivideo.ax ... and not found it.... also the folder ABIT does not exists....
i have reinstalled win 2000 pro sp2... inserted abit siluro cd .. installed card ... installed elecard filters ... installed DVBViewer and .. same again :)
picture shows for 5 seconds and then .. slide show .\(picture 1sec , blank screen 2 sec, picture 1 sec, ....._. ....
Tryed with all possible combinations of rendering and still no success ....
Guest hackbart
Which version do you use?
Christian
Guest hackbart
Well could you please check the following thing:
there are two routines inside the demo, the first one appears if you tune a radio channel in and push in the about box the logo (in combination with ctrl-key). The second thing is the News-Function, just push it and post the text which cames up (this helps me to determine what your latest release is). As you might realized i update the whole project rather often (in a ~3 days period)...
Christian
DVBViewer V1.98R20
- fastest EPG
- new Whats Else Function
- a couple of bugfixes
- fixed Sonic DVD Codec bug
DVBViewer V1.98R19
- menu entries slightly modified
- DVD support enhanced (Pause/Stop/Jumping etc)
- fixed the Runtime Error issue with active Ligos Decoder
DVBViewer V1.98R18
- added epg store routine
- fixed bucking bug on several machines
- fixed 2nd monitor problem
DVBViewer V1.98R17
- lot of small fixes (caused by problems with no admin restrictions)
- new super fast channeleditor (tnx to griga)
- two new iconsets
DVBViewer V1.98R16
- bugfix in PidDump Tool
- added LAN support
- a couple of smaller fixes
DVBViewer V1.98R15
- new PidDump Tool
- XVR Renderer support
DVBViewer V1.98R13
- Added "time till End of event"-Counter
- Removed the stop recording if hdd is full
- Scanner is now a bit more accurate
DVBViewer V1.98R12
- Duration could be optionally displayed instead of signal strength
- Screen Positions are now remembered
- Fixed a bug in the Scan-routine
DVBViewer V1.98R11
- DiSEqC was not working with Marfi's Filter
- Optimized some parts in the source
- If Audio is switching Stereo/Mono Bitrate the Graph is updating
DVBViewer V1.98R10
- Fixed a bug in the channel switch
- Fixed the a bug in the Priority settings
- Optimized the EIT/Teletext Data Parser
DVBViewer V1.98R9
- Added a recorder statuswindow
- Added possibility to change the Priority
DVBViewer V1.98R8
- Marfi Updated his renderer, 4hours timeshift and much more
- i updated some language files
- Have a happy new year !!
DVBViewer V1.98R7
- Audio only resp. Video only Stream could be saved seperately
- Color Settings could be set via Shortcuts
- Small Realign-Videowindow bug fixed
DVBViewer V1.98R6
- i was yet again too fast with releasing a new version (a few small things left)
- probably the most stablest version ever :)
DVBViewer V1.98R5
- Skins are not supported yet (caused by ugly problems of the engine)
- fixed a bug in the Teletext pages
- fixed smaller bugs
- updated language files (thanks to my translators)
DVBViewer V1.98R4
- Fixed a problem if the System does not use 24h mode
- Fixed a problem if the Drag'n' Drop Channellist
- Plugins are now able to receive PID Data
DVBViewer V1.98R3
- Colorsettings are no longer forgotten while Fast Channelswitch is active
- Enhanced Plugins
- Channeleditor supports now Drag'n' Drop
- www.DVBViewer.com/download/pluginsrc.zip contains the Plugin Specification
DVBViewer V1.98R2
- Fixed a small rendering bug in the Teletext Engine
- Solved the BVN, Rai 1,2,3 recording problem
- Made the recorder.exe compatible to Michaels Frontend
DVBViewer V1.98R1
- Fixed a small EPG Window function to detect the Channelnames
- Fixed a small bug in the recorder.exe which caused problems in the pva format
- Dedynamic Filtering can be disabled on radio channels
- Teletext could be controlled via Lirc
- Installer remembers Usersettings
DVBViewer V1.98
- EPG Window can now display all running events
- The channel scanner does no longer choke Transponder with more than 20 channels
- Channel Editor has a few new Shortcuts for (re)moving channels
- On channels like Xtra Music the active song is displayed in the Mini-EPG
- English Translation is now more detailed
- Added Horizontal & Vertical Stretch
DVBViewer V1.97R7
- Some new shortcuts for the channeleditor
- Fixed a Problem with non-conform teletext
DVBViewer V1.97R6
- Channels could be moved in the Channeleditor
- Fixed a small Bug in the Filenamegenerator for recorded files
- Improved .MDB Importer (thanks to Philippe)
DVBViewer V1.97R5
- External recorder is updated (PVA)
- Rudimentary Cable, ATSC and Terrestrial support
DVBViewer V1.97R4
- Channeleditor problems fixed
- Marfi's Renderer works always in stereo and detects
Stereo-Mono changes
- Channelswitch is using the index of the sorted
list
- Traybar Icon shows the current event
- Runtimeerror 216 on exit fixed
- Faster News Funktion
DVBViewer V1.97R2
- Fixed Small bug while loading Videos
- Removed a small routine while closing the application
DVBViewer V1.97R1
- Menu restructured
- Fixed a small bug in the PVA recorder
- Recorder now uses API Functions instead of the
TFileStream-class
- Timeshifting can now be stopped
- Fixed Transponder 12048 Mhz Problem
- DVBViewer speaks now also japanese
- Videosinformations are shown each time a video
is loaded
