esperado Posted May 26, 2006 Posted May 26, 2006 (edited) (I don't know if it is the good place for posting this. Admins, feel free to deplace this post). It is very easy to get your Pinnacle remote working with DVBViewer, with the original remote program of Pinnacle. 1- You need the original remote prog installed. (It is done with the installation of Pinnacle Mediacenter). ############################################### 2- Unzip the attached file and Copy "DVBViewerPinnacle.remote" in your: DVBViewer\remotes folder. Settings > option > Inputs > "load" (this file). 3-Find your ...\Pinnacle\Sharedfiles\Programs\remote folder. Save your original Profiles.ini file under an other name (ex: profilesOriginal.ini), and copy this "profiles.ini" in the folder. Enjoy. (Devs, feel free to add thoses file to DVBViewer if you like) ############################################### OR ############################################### 2- Localize the folder Pinnacle\Sharedfiles\Programs\remote. You will find a file nammed: profiles.ini. 3- Make a security backup of this file (ex: profilesOriginal.ini). 4 -Open the profiles.ini in a text editor. (It is plain text). It looks like: ________________________________________________________ [default] ; start PMC with Remote Type A key38=EXEC J:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe| -10ft -full ; ; start PMC with Remote Type B key1006=EXEC J:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe| -10ft -full ; ; Autorun ;HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run autorunkey=PMCRemote ;bla ;bla ;bla [Pinnacle Media Center] ;*************** ; Remote Type A ;*************** ;bla ;bla ;bla ;*************** ; Remote Type B ;*************** ;bla ;bla ;bla ;**************************** ; Remote Settings for HTML Plugin interface ;**************************** ;bla ;bla ;bla __________________________________________________ 5 - If you wishe DVBViewer to start with your remote, Replace: key38=EXEC J:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe| -10ft -full by: key38=EXEC \Your_DVBViewer_installation_folder_Path\DVBViewer.exe and (or, according of your remote's type): key1006=EXEC J:\PROGRA~1\Pinnacle\MEDIAC~1\PMC.exe| -10ft -full by: key1006=EXEC \Your_DVBViewer_installation_folder_Path\DVBViewer.exe 6- At the end of the file, add: [DVBViewer Skin] or, if you don't use skin: [DVBViewer] copy everything which is under: ;*************** ; Remote Type A ;*************** or ( and, if you dont know if your remote is A or B ) ;*************** ; Remote Type B ;*************** (No need to copy the: ;**************************** ; Remote Settings for HTML Plugin interface.... entries ;**************************** ) 7- At the end of the file, create a new entry: [Options] and copy the same that you done under [DVBViewer Skin]. Now, your file look like: _____________________________________________________ [default] ;bla ;bla ;bla [Pinnacle Media Center] ;bli ;bli ;bli ;**************************** ; Remote Settings for HTML Plugin interface ;**************************** ;blo ;blo ;blo [DVBViewer Skin] ;bli ;bli ;bli [Options] ;bli ;bli ;bli _________________________________________________ 8- Save this file under the name: "profiles.ini" Your Pinnacle remote is now working with DVBViewer as well as with the original media center prog. 9- Open Settings/options/Input, and map the fonctions you want with the learn function. That's-it. Pinnacle_Remote.zip Edited June 2, 2006 by esperado Quote
pegl Posted June 1, 2006 Posted June 1, 2006 Many thanks to You esperado I just got my remote for Pinnacle PCTV 300i to work with DVBViewer. regards pegl Quote
djt1990 Posted January 28, 2008 Posted January 28, 2008 can someone upload the files, i just cant get it to work...!! Quote
Marju68 Posted May 4, 2008 Posted May 4, 2008 Wie kann ich jetzt hier Tastaturbefehle ändern, bei mir stimmt die nicht ich möchte das OSD auf DVBViewer beenden legen Ich versuch schon den ganzen morgen daran, bitte helft mir Meine Profil.ini ; Christophe Esperado <ch.esperado@libertysurf.fr> ; http://esperado.dyndns.tv [default] ; start PMC with Remote Type A key38=EXEC ..\..\..\MediaCenter\pmc.exe| /10ft ; ; start PMC with Remote Type B key1006=EXEC ..\..\..\MediaCenter\pmc.exe| /10ft ; ; Autorun ;HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run autorunkey=PMCRemote ; ; hardware ID: -1 = autodetect HWID=4 port=1 rc_id1=1 rc_id2=0 rc_filter=all ; ;######################################################################## [DVBViewer] ;*************** ; Remote Type A ;*************** ; ; FastForward key7=KEYBOARD f+^f ; Stop key11=KEYBOARD s+^s ; Play key13=KEYBOARD p+^p ; FastRewind key14=KEYBOARD r+^r ; Volume down key15=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key79=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key19=KEYBOARD CTRL+RIGHT+^RIGHT+^CTRL ; pause key21=KEYBOARD BLANK+^BLANK ; back or jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key22=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; page up or channel up key23=KEYBOARD PGUP+^PGUP key87=KEYBOARD PGUP+^PGUP ; EPG key24=KEYBOARD F8+^F8 ; LiveTV key25=KEYBOARD ESC ; select key26=KEYBOARD ENTER+^ENTER ; volume up key27=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key91=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key28=KEYBOARD PGDN+^PGDN key92=KEYBOARD PGDN+^PGDN ; Menue or settings key29=KEYBOARD ALT+m+^m+^ALT ; zoom key30=KEYBOARD ALT+z+^z+^ALT ; channel list (only in TV mode) key31=KEYBOARD ENTER+^ENTER ; last channel; toggle between the last two channel (viewed >=10sec) key37=KEYBOARD ALT+l+^l+^ALT ; goto TV key38=KEYBOARD F5+^F5 ; capture key39=KEYBOARD c+^c ; goto teletext key41=KEYBOARD F6+^F6 ; goto radio key42=KEYBOARD F7+^F7 ; get info key43=KEYBOARD ALT+i+^i+^ALT ; fullscreen key45=KEYBOARD ALT+f+^f+^ALT ; multi station preview key46=KEYBOARD ALT+p+^p+^ALT ; turn off key47=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key49=KEYBOARD 1+^1 ; numeric key 2 key50=KEYBOARD 2+^2 ; numeric key 3 key51=KEYBOARD 3+^3 ; numeric key 4 key52=KEYBOARD 4+^4 ; numeric key 5 key53=KEYBOARD 5+^5 ; numeric key 6 key54=KEYBOARD 6+^6 ; numeric key 7 key55=KEYBOARD 7+^7 ; numeric key 8 key56=KEYBOARD 8+^8 ; numeric key 9 key57=KEYBOARD 9+^9 ; numeric key 0 and AV selector key58=KEYBOARD 0+^0 ; navigate : right key59=KEYBOARD RIGHT+^RIGHT ; mute audio key60=KEYBOARD m+^m ; navigate : left key61=KEYBOARD LEFT+^LEFT ; navigate : down key62=KEYBOARD DOWN+^DOWN key126=KEYBOARD DOWN+^DOWN ; navigate : up key63=KEYBOARD UP+^UP key127=KEYBOARD UP+^UP ; ; ;*************** ; Remote Type B ;*************** ; ; FastForward key1036=KEYBOARD f+^f ; Stop key1038=KEYBOARD s+^s ; Play key1047=KEYBOARD p+^p ; FastRewind key1034=KEYBOARD r+^r ; Volume down key1044=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key1108=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key1039=KEYBOARD CTRL+RIGHT+^RIGHT+^CTRL ; pause key1035=KEYBOARD BLANK+^BLANK ; jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1037=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; back ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1013=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; page up or channel up key1015=KEYBOARD PGUP+^PGUP key1079=KEYBOARD PGUP+^PGUP ; EPG key1042=KEYBOARD F8+^F8 ; LiveTV key1041=KEYBOARD F5+^F5 ; select key1021=KEYBOARD ENTER+^ENTER ; volume up key1043=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key1107=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key1016=KEYBOARD PGDN+^PGDN key1080=KEYBOARD PGDN+^PGDN ; Menue or settings, (green button () key1010=KEYBOARD ALT+m+^m+^ALT ; zoom , (yellow button ©) key1011=KEYBOARD ALT+z+^z+^ALT ; channel list (only in TV mode) key1021=KEYBOARD ENTER+^ENTER ; last channel; toggle between the last two channel (viewed >=10sec) key1045=KEYBOARD ALT+l+^l+^ALT ; goto TV key1041=KEYBOARD F5+^F5 ; capture key1046=KEYBOARD c+^c ; goto teletext key1040=KEYBOARD F6+^F6 ; goto radio ; ---------- no assigned button ----- ; get info (blue button (?)) key1012=KEYBOARD ALT+i+^i+^ALT ; fullscreen key1008=KEYBOARD ALT+f+^f+^ALT ; multi station preview ; ---------- no assigned button ----- ; turn off key1002=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key1022=KEYBOARD 1+^1 ; numeric key 2 key1023=KEYBOARD 2+^2 ; numeric key 3 key1024=KEYBOARD 3+^3 ; numeric key 4 key1025=KEYBOARD 4+^4 ; numeric key 5 key1026=KEYBOARD 5+^5 ; numeric key 6 key1027=KEYBOARD 6 ; numeric key 7 key1028=KEYBOARD 7+^7 ; numeric key 8 key1029=KEYBOARD 8+^8 ; numeric key 9 key1030=KEYBOARD 9+^9 ; numeric key 0 and AV selector key1032=KEYBOARD 0+^0 ; navigate : right key1020=KEYBOARD RIGHT+^RIGHT ; mute audio key1001=KEYBOARD m+^m ; navigate : left key1019=KEYBOARD LEFT+^LEFT ; navigate : down key1018=KEYBOARD DOWN+^DOWN key1082=KEYBOARD DOWN+^DOWN ; navigate : up key1017=KEYBOARD UP+^UP key1081=KEYBOARD UP+^UP ; aspect ration (red button (A)) key1009=KEYBOARD a+^a ; home or PMC start key1006=KEYBOARD ESC+^ESC ; c/n key1031=KEYBOARD CTRL+c+^c+^CTRL ; del key1033=KEYBOARD DEL+^DEL ;######################################################################## [Options] ;*************** ; Remote Type A ;*************** ; ; FastForward key7=KEYBOARD f+^f ; Stop key11=KEYBOARD s+^s ; Play key13=KEYBOARD p+^p ; FastRewind key14=KEYBOARD r+^r ; Volume down key15=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key79=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key19=KEYBOARD CTRL+RIGHT+^RIGHT+^CTRL ; pause key21=KEYBOARD BLANK+^BLANK ; back or jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key22=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; page up or channel up key23=KEYBOARD PGUP+^PGUP key87=KEYBOARD PGUP+^PGUP ; EPG key24=KEYBOARD F8+^F8 ; LiveTV key25=KEYBOARD F5+^F5 ; select key26=KEYBOARD ENTER+^ENTER ; volume up key27=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key91=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key28=KEYBOARD PGDN+^PGDN key92=KEYBOARD PGDN+^PGDN ; Menue or settings key29=KEYBOARD ALT+m+^m+^ALT ; zoom key30=KEYBOARD ALT+z+^z+^ALT ; channel list (only in TV mode) key31=KEYBOARD ENTER+^ENTER ; last channel; toggle between the last two channel (viewed >=10sec) key37=KEYBOARD ALT+l+^l+^ALT ; goto TV key38=KEYBOARD F5+^F5 ; capture key39=KEYBOARD c+^c ; goto teletext key41=KEYBOARD F6+^F6 ; goto radio key42=KEYBOARD F7+^F7 ; get info key43=KEYBOARD ALT+i+^i+^ALT ; fullscreen key45=KEYBOARD ALT+f+^f+^ALT ; multi station preview key46=KEYBOARD ALT+p+^p+^ALT ; turn off key47=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key49=KEYBOARD 1+^1 ; numeric key 2 key50=KEYBOARD 2+^2 ; numeric key 3 key51=KEYBOARD 3+^3 ; numeric key 4 key52=KEYBOARD 4+^4 ; numeric key 5 key53=KEYBOARD 5+^5 ; numeric key 6 key54=KEYBOARD 6+^6 ; numeric key 7 key55=KEYBOARD 7+^7 ; numeric key 8 key56=KEYBOARD 8+^8 ; numeric key 9 key57=KEYBOARD 9+^9 ; numeric key 0 and AV selector key58=KEYBOARD 0+^0 ; navigate : right key59=KEYBOARD RIGHT+^RIGHT ; mute audio key60=KEYBOARD m+^m ; navigate : left key61=KEYBOARD LEFT+^LEFT ; navigate : down key62=KEYBOARD DOWN+^DOWN key126=KEYBOARD DOWN+^DOWN ; navigate : up key63=KEYBOARD UP+^UP key127=KEYBOARD UP+^UP ; ; ;*************** ; Remote Type B ;*************** ; ; FastForward key1036=KEYBOARD f+^f ; Stop key1038=KEYBOARD s+^s ; Play key1047=KEYBOARD p+^p ; FastRewind key1034=KEYBOARD r+^r ; Volume down key1044=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key1108=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key1039=KEYBOARD CTRL+RIGHT+^RIGHT+^CTRL ; pause key1035=KEYBOARD BLANK+^BLANK ; jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1037=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; back ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1013=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; page up or channel up key1015=KEYBOARD PGUP+^PGUP key1079=KEYBOARD PGUP+^PGUP ; EPG key1042=KEYBOARD F8+^F8 ; LiveTV key1041=KEYBOARD F5+^F5 ; select key1021=KEYBOARD ENTER+^ENTER ; volume up key1043=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key1107=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key1016=KEYBOARD PGDN+^PGDN key1080=KEYBOARD PGDN+^PGDN ; Menue or settings, (green button () key1010=KEYBOARD ALT+m+^m+^ALT ; zoom , (yellow button ©) key1011=KEYBOARD ALT+z+^z+^ALT ; channel list (only in TV mode) key1021=KEYBOARD ENTER+^ENTER ; last channel; toggle between the last two channel (viewed >=10sec) key1045=KEYBOARD ALT+l+^l+^ALT ; goto TV key1041=KEYBOARD F5+^F5 ; capture key1046=KEYBOARD c+^c ; goto teletext key1040=KEYBOARD F6+^F6 ; goto radio ; ---------- no assigned button ----- ; get info (blue button (?)) key1012=KEYBOARD ALT+i+^i+^ALT ; fullscreen key1008=KEYBOARD ALT+f+^f+^ALT ; multi station preview ; ---------- no assigned button ----- ; turn off key1002=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key1022=KEYBOARD 1+^1 ; numeric key 2 key1023=KEYBOARD 2+^2 ; numeric key 3 key1024=KEYBOARD 3+^3 ; numeric key 4 key1025=KEYBOARD 4+^4 ; numeric key 5 key1026=KEYBOARD 5+^5 ; numeric key 6 key1027=KEYBOARD 6+^6 ; numeric key 7 key1028=KEYBOARD 7+^7 ; numeric key 8 key1029=KEYBOARD 8+^8 ; numeric key 9 key1030=KEYBOARD 9+^9 ; numeric key 0 and AV selector key1032=KEYBOARD 0+^0 ; navigate : right key1020=KEYBOARD RIGHT+^RIGHT ; mute audio key1001=KEYBOARD m+^m ; navigate : left key1019=KEYBOARD LEFT+^LEFT ; navigate : down key1018=KEYBOARD DOWN+^DOWN key1082=KEYBOARD DOWN+^DOWN ; navigate : up key1017=KEYBOARD UP+^UP key1081=KEYBOARD UP+^UP ; aspect ration (red button (A)) key1009=KEYBOARD a+^a ; home or PMC start key1006=KEYBOARD ESC+^ESC ; c/n key1031=KEYBOARD CTRL+c+^c+^CTRL ; del key1033=KEYBOARD DEL+^DEL ;############################################################################### ############# [DVBViewer Skin] ;*************** ; Remote Type A ;*************** ; ; FastForward key7=KEYBOARD f+^f ; Stop key11=KEYBOARD s+^s ; Play key13=KEYBOARD p+^p ; FastRewind key14=KEYBOARD r+^r ; Volume down key15=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key79=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key19=KEYBOARD CTRL+RIGHT+^RIGHT+^CTRL ; pause key21=KEYBOARD BLANK+^BLANK ; back or jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key22=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; page up or channel up key23=KEYBOARD PGUP+^PGUP key87=KEYBOARD PGUP+^PGUP ; EPG key24=KEYBOARD F8+^F8 ; LiveTV key25=KEYBOARD F5+^F5 ; select key26=KEYBOARD ENTER+^ENTER ; volume up key27=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key91=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key28=KEYBOARD PGDN+^PGDN key92=KEYBOARD PGDN+^PGDN ; Menue or settings key29=KEYBOARD ALT+m+^m+^ALT ; zoom key30=KEYBOARD ALT+z+^z+^ALT ; channel list (only in TV mode) key31=KEYBOARD ENTER+^ENTER ; last channel; toggle between the last two channel (viewed >=10sec) key37=KEYBOARD ALT+l+^l+^ALT ; goto TV key38=KEYBOARD F5+^F5 ; capture key39=KEYBOARD c+^c ; goto teletext key41=KEYBOARD F6+^F6 ; goto radio key42=KEYBOARD F7+^F7 ; get info key43=KEYBOARD ALT+i+^i+^ALT ; fullscreen key45=KEYBOARD ALT+f+^f+^ALT ; multi station preview key46=KEYBOARD ALT+p+^p+^ALT ; turn off key47=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key49=KEYBOARD 1+^1 ; numeric key 2 key50=KEYBOARD 2+^2 ; numeric key 3 key51=KEYBOARD 3+^3 ; numeric key 4 key52=KEYBOARD 4+^4 ; numeric key 5 key53=KEYBOARD 5+^5 ; numeric key 6 key54=KEYBOARD 6+^6 ; numeric key 7 key55=KEYBOARD 7+^7 ; numeric key 8 key56=KEYBOARD 8+^8 ; numeric key 9 key57=KEYBOARD 9+^9 ; numeric key 0 and AV selector key58=KEYBOARD 0+^0 ; navigate : right key59=KEYBOARD RIGHT+^RIGHT ; mute audio key60=KEYBOARD m+^m ; navigate : left key61=KEYBOARD LEFT+^LEFT ; navigate : down key62=KEYBOARD DOWN+^DOWN key126=KEYBOARD DOWN+^DOWN ; navigate : up key63=KEYBOARD UP+^UP key127=KEYBOARD UP+^UP ; ; ;*************** ; Remote Type B ;*************** ; ; FastForward key1036=KEYBOARD f+^f ; Stop key1038=KEYBOARD s+^s ; Play key1047=KEYBOARD p+^p ; FastRewind key1034=KEYBOARD r+^r ; Volume down key1044=KEYBOARD CTRL+PGDN+^PGDN+^CTRL key1108=KEYBOARD CTRL+PGDN+^PGDN+^CTRL ; next chapter key1039=KEYBOARD CTRL+RIGHT+^RIGHT+^CTRL ; pause key1035=KEYBOARD BLANK+^BLANK ; jump to start of the current chapter or if pressed twice to the previous chapter ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1037=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; back ; this key has three different keyboard key 'back', 'POS1' and 'CTRL+LEFT' key1013=KEYBOARD CTRL+LEFT+^LEFT+^CTRL ; page up or channel up key1015=KEYBOARD PGUP+^PGUP key1079=KEYBOARD PGUP+^PGUP ; EPG key1042=KEYBOARD F8+^F8 ; LiveTV key1041=KEYBOARD F5+^F5 ; select key1021=KEYBOARD ENTER+^ENTER ; volume up key1043=KEYBOARD CTRL+PGUP+^PGUP+^CTRL key1107=KEYBOARD CTRL+PGUP+^PGUP+^CTRL ; page down or channel down key1016=KEYBOARD PGDN+^PGDN key1080=KEYBOARD PGDN+^PGDN ; Menue or settings, (green button () key1010=KEYBOARD ALT+m+^m+^ALT ; zoom , (yellow button ©) key1011=KEYBOARD ALT+z+^z+^ALT ; channel list (only in TV mode) key1021=KEYBOARD ENTER+^ENTER ; last channel; toggle between the last two channel (viewed >=10sec) key1045=KEYBOARD ALT+l+^l+^ALT ; goto TV key1041=KEYBOARD F5+^F5 ; capture key1046=KEYBOARD c+^c ; goto teletext key1040=KEYBOARD F6+^F6 ; goto radio ; ---------- no assigned button ----- ; get info (blue button (?)) key1012=KEYBOARD ALT+i+^i+^ALT ; fullscreen key1008=KEYBOARD ALT+f+^f+^ALT ; multi station preview ; ---------- no assigned button ----- ; turn off key1002=KEYBOARD ALT+F4+^F4+^ALT ; numeric key 1 key1022=KEYBOARD 1+^1 ; numeric key 2 key1023=KEYBOARD 2+^2 ; numeric key 3 key1024=KEYBOARD 3+^3 ; numeric key 4 key1025=KEYBOARD 4+^4 ; numeric key 5 key1026=KEYBOARD 5+^5 ; numeric key 6 key1027=KEYBOARD 6 ; numeric key 7 key1028=KEYBOARD 7+^7 ; numeric key 8 key1029=KEYBOARD 8+^8 ; numeric key 9 key1030=KEYBOARD 9+^9 ; numeric key 0 and AV selector key1032=KEYBOARD 0+^0 ; navigate : right key1020=KEYBOARD RIGHT+^RIGHT ; mute audio key1001=KEYBOARD m+^m ; navigate : left key1019=KEYBOARD LEFT+^LEFT ; navigate : down key1018=KEYBOARD DOWN+^DOWN key1082=KEYBOARD DOWN+^DOWN ; navigate : up key1017=KEYBOARD UP+^UP key1081=KEYBOARD UP+^UP ; aspect ration (red button (A)) key1009=KEYBOARD a+^a ; home or PMC start key1006=KEYBOARD ESC+^ESC ; c/n key1031=KEYBOARD CTRL+c+^c+^CTRL ; del key1033=KEYBOARD DEL+^DEL Quote
chrille Posted April 29, 2009 Posted April 29, 2009 how can i change some shotcuts? have to edit it, because i have a pinnacle pctv 310i http://img13.myimg.de/Unbenanntc6e5a.jpg and some keys aren't work. (sry for bad english) mfg ch Quote
