Picture position
chegg
I have different picture-positions on different channels.
The most of the channels are working fine. The picture appears in the center of the screen, but on some channels the picture is all to the left and ends in the middle of the screen. The rest of the screen is black.
Does anyone know how to fix this? Can I setup each channels pictureposition or will all my other channels, that i´m satisfied with, also change position then?
I have tried auto and 16:9 but as I said, some channels are pretty messed up.
Guest Lars_MQ
try another video decoder and don't use the elecard. (options -> directx)
Thanks! I thought I already tested that but I had to try all the combinations of decoders and rendering. At the very last try everything worked out good! Even the HD-channels run smooth.
Thanks for the quick response, amazing!
