Dvico cards support
Silenius
Sorry for this question but I didn't find anything about this on the forum (I precise that I can't read german :( )
Does DVBViewer supports the DVICO fusion HDTV card?
Maybe the beta version does?
This is a key point to make me buy (or not) this software. :(
Thanks
Sil
you can test your card (with BDA driver installed)
if you use the tool Transedit MMC from this site
and make a channelscan,
it's work -> the DVBViewer Pro will work
It works! :wub:
Thank you for your quick answer!!
Sil
