feucar Posted June 5, 2006 Posted June 5, 2006 Hi, I'd like to know if the Hauppauge HVR1300 is supported by DVBViewer pro for DVB-T receiving. (I hope it is a Hauppauge HVR1100 + analog) Thanks Quote
hdv Posted June 5, 2006 Posted June 5, 2006 Hallo, you can test your card (with BDA driver installed) if you use the tool Transedit MMC from this site and make a channelscan, it's work -> the DVBViewer Pro will work look on this site for BDA driver, if you have not installed yet Quote
Engelbert Posted June 5, 2006 Posted June 5, 2006 No, the Hauppauge HVR 1300 is an HVR 1100 + Hardware-Decoder Quote
hdv Posted June 5, 2006 Posted June 5, 2006 Hallo, No, the Hauppauge HVR 1300 is an HVR 1100 + Hardware-Decoder it's wrong the HVR 1300 has a hardware encoder for analog capture look here WinTV-HVR-1300 make a test with Transedit MMC Quote
Engelbert Posted June 5, 2006 Posted June 5, 2006 (edited) Hauppauge HVR 1300: 'Record digital TV to your PC's hard disk using high quality hardware MPEG-2.' Sorry, the Hauppauge HVR1300 is not supported by DVBViewer. Edited June 6, 2006 by Engelbert Quote
finnbuhl Posted June 12, 2006 Posted June 12, 2006 I have a HVR-1300 running on a Windows MCE with the DVBViewer - and it runs very fine. But I found it quite difficult to make a channel list and get it into the DVBViewer. This could also be beacuse I am quite new in DVBViewer. BTW where can I find a quide to setup my MCE remote control for the DVBViewer ? Quote
Creagan Posted October 13, 2006 Posted October 13, 2006 I have a HVR-1300 running on a Windows MCE with the DVBViewer - and it runs very fine. But I found it quite difficult to make a channel list and get it into the DVBViewer. This could also be beacuse I am quite new in DVBViewer. BTW where can I find a quide to setup my MCE remote control for the DVBViewer ? How did you managed to get your 1300 to work with DVBViewer? All I get is "No hardware available" Please help...? Quote
Tjod Posted October 13, 2006 Posted October 13, 2006 All I get is "No hardware available"Try a channel scan because there are only DVB-S channel at the first start. Quote
Dvb-tv Posted October 20, 2006 Posted October 20, 2006 Support for Hauppauge HVR1300 DVB-T only By DVB-T if you mean digital terestrial television only. I would have though this tuner with DVBViewer would work, please correct me if i'm wrong. As the HVR-1300 is exactly same tuner as the nova-t for digital DTT or DVB-T as in the thread heading. See this link for devices and here for Nova-t and HVR family drivers. Yes the HVR has analogue also, i'm replying to the thread heading Support for Hauppauge HVR1300 DVB-T only Quote
pgudge Posted March 3, 2007 Posted March 3, 2007 Slightly old, but I've been running DVBViewer with 2 HVR-1300 for awhile. It also allows me to record on different muxes, works awesome. p Quote
