New Beta 3.4.11
Guest Lars_MQ
Guest Lars_MQ
A new beta in the Membersarea.
Version BETA 3.4.11.0
[*]Add: Recorderwindow: The day is shown in front of the date.
[*]Fix: DVBSubs/Timeshift: Removed forgotten code which prevented dvbsubs in timeshift. (untested)
[*]Add: Teletextsubtitles: Selected Teletextsubtitles are saved and restored.
[*]Fix: HTPC-Mode: Fixed problem opening the options window.
[*]Change: Encrypted Channels: If a encrypted channel is tuned, which can't be decrypted the channelname in the statusbar is marked with a '*'.
[*]Fix: TerratecBDA: Fixed DiseqC handling. (untested)
[*]Add: Networkdevices: You can add multiple Networkdevices now. Simply add a section to the usermode.ini:
        [Card]
        Unicast=1
        Multicast=1
there you can set the numbers of devices. After that start the DVBViewer and do a devicedetection in the options. Don't forget to configure the devices.
[*]Update: Updated language files.
[*]Fix: COM: Fixed the WindowID in COM-Event.
Have Fun!
Danke !!! :wub:
Gruß, dgdg
