Phoenix Smartmouse reader support
Silenius
Hello,
does DVBViewer support the Phoenix Smartmouse reader (native or via plugin)? I'd like to watch pay channels (legally of course!) but I don't have CI on my sat card (SS2).
Thanks
Sil
The forum rules do not allow this question, because softcams are not legal! We had this discussion several times...
sorry :oops:
Thanks for your answer ;)
  • 1 month later...
Correction to that.
[removed] are perfectly legal. At least in all EU countries, and to my knowledge also in USA.
That is as long as you use geniue smartcard from Cable/Satellite operator.
Technically these is no difference between [removed] and CAM module that is connected to DVB card.
Yes it is true that [removed] can be used with pirate keys. But CAM module can be used with pirate card so no difference.
Actually I myself am currently looking for [removed, violating forum rule §13] for DVBViewer.
And yes I do have subscription from my cable operator.
Jarno
No, you're wrong! DVB uses the common scrambling algorithm CSA. To make use of this algo, a hardware implementation is mandatory ! Check with ETSI.
