Freezes passing 5 minutes since I tune a channel
ozobucos@hotmail.com
First excuse me for my bad english.
The problem happen with all DVBViewer PRO versions and all Skystar2 drives that I tested. It's a rare problem because DVBViewer start working fine with a very good image, with 25 fps, perfect... but at 4 or 5 minutes frames drop under 15 fps and only get back 25 fps if I re-tune the channel, re-build filter or choose another filter graph but again drop frames at 4 or 5 minutes. Other DVB programs like Mytheatre or HispaDVB work fine. My graphic video card it's ATI RADEON 9550. I use Windows XP PRO service pack 1. AMD Athlon 1.200 MHz, 512 MB RAM. Skystar2 pci card. No other DVB card in my pc.
Saludos.
Guest Lars_MQ
Please remove all plugins, except the ones directly related with DVBViewer and test again.
WITHOUT PLUGINS PERSIST THE PROBLEM. THAT IS NOT THE SOLUTION.
Version 3.4.12.1 beta work fine, no freezes and no droping frames ;):blush:
