Jump Button
tlauks
I'm missing a simple jump-to-previous-channel button. I have one on my tv-remote-control and I use it quite often. Could you implement this button or hotkey?
Should not be too complicate and will be very effective and usefull.
Thanx, Tom
As mostly....
I like the idea!!! :o)
I'd like that too.
What do you think about replacing the DVBViewer favourite list (which isn't good anyway) by a "Most Recently Used" list?
The Station +/- buttons could be used for switching through the last ten used channels then...
Everybody who would like to maintain the old favourite list, enter your protest here! :)
Griga
I think that be usefull to have prefered channel (the shortcuts is configurable) and the list of last visited channell (usable with station+/- buttons/shortcuts).
damjang
Guest Michael
I'd like that too.
Griga
i want both ;)
i want both ;)
me2! ;)B)
Don't even think of screwing up the favorites' list. :)
Salut !
Well I don't mind kicking the favourites, as they are mixed up each time I end my DVBViewer and I have more than ten favourites, so I remember the channelnumbers :-(
What about an additional toolbar (configurable) with the favourites? Using the icons provided by Griga for the links.
Guest Michael
the icons would screw up the size of the channels.dat :)
Don't You dare touching the favourite-list !!!!!!!!!!!!!!!!!! ;)
10 favourites is not much but much better than no favourites.... :)
A single last-used-hotkey would be pretty much enough for me... ;)
I wasn't thinking of something related to the Channels.dat, afaik that is only related to the whole channel list.
I was rather thinking about a free configurable toolbar, where you can define your own icons to certain commands including switching to a certain channel.
Guest hackbart
errm, sorry i read the thread too late ;) I've added the "Jump to Last Channel" and it will be available tomorrow in the new release. The only thing i have to fix till then, is the "Al Jaseera broadcasts Heidi" problem. The simple reason is that the service id's are given more than 1x on different satellites :)
Christian
