ocho Posted June 13, 2006 Posted June 13, 2006 i have no status bar or toolbar both are selected in the view menu but both are ghosted keyboard shortcuts have no effect either any ideas? Quote
Klausing Posted June 13, 2006 Posted June 13, 2006 make a right click in the window and you can make them visible. Quote
Guest Lars_MQ Posted June 14, 2006 Posted June 14, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
Guest Lars_MQ Posted June 14, 2006 Posted June 14, 2006 Please rename you setup.xml and the start the DVBViewer. it seems the skin you're using is corrupt. Can find the file in "G:\Documents and Settings\All Users\Application Data\DVBViewer Pro\" Quote
