Recorder Time-Overhead
fesche
Salut !
PVR-tools has a nice option to set a default time offset (in minutes) for entered recording start and end.
May it would be helpful to enter two parameters:
a) offset to start BEFORE rec-Starttime
:) offset to finish AFTER rec time.
e.g. If I want to record a film from EPG, start AND end-times are taken over as usual, but the recorder will start
recording minutes before starttime in rec-entry and will continue recording minutes after
endtime in rec-entry !
thx in advance. :-)
  • 9 months later...
100 % agree !!!!
this is a must and can not be too hard to implement (esp. compared to other features implemented in the DVBViewer).
as you can never rely on the exact epg times i always add 5 minutes before and up to 20 minutes after the program to be sure to record the whole broadcast.
would be real nice not to have to do that manually each time.
guido
