memyself Posted June 15, 2006 Posted June 15, 2006 Hi Im new to DVBViewer. I Bought it yesterday and use it with a MSI Mega Sky DVB-T 580 USB dongle. I use it too see the free DVB-T channels in Sweden, and it works fine. The goal is to use it to see some of the games from Soccer WC in HDTV, I bought the CoreAVC Pro for that. Some times I can see the HD-channel with no problems (some lagbut its ok). When I get picture the resolution is 1024x720. But than I restart the PC and try again I get no picture (but sound) and the lower bar in the window display 1920x1088. Why? Can I set the resolution to 1024x720 manually for that channel? Thanks in advanced! Quote
Griga Posted June 15, 2006 Posted June 15, 2006 and the lower bar in the window display 1920x1088. That's just a default H.264 resolution reported by the DVBViewer Filter in case it gets no video data. Can I set the resolution to 1024x720 manually for that channel? No. Wouldn't solve the problem anyway. Quote
memyself Posted June 16, 2006 Author Posted June 16, 2006 Hi Thanks, than I know! I may have some trouble with the signal, will check later today... Quote
