PVAstrumento creates beeps and blops?
fesche
Salut !
I just tried to convert my MPEG recorded File to PVA because I wanted to append two files together,
but then I found out that after converting to PVA the sound got damaged with unregular beeps and blops.
1. has anybody an idea ?
Of course I tried to watch the original PMPEG, but this is playing well !
2. Is there a tool to cut / append mpeg files without need to convert 1000 times ? Or even just cutting would be fine !
thx.
Salut !
I just found out that I blamed PVAstrumento unreasonably. It is PVAcut that produces theese beeps and blops !!!!!!!
Furthermore PVAcut destroyed my synchronisation !!
I Just checked The files, and here is what I did....
1. recorded mpeg2 stream
2. converted to pva with PVAstrumento this is the output:
*** PVAStrumento 2.0.26
*** running at 03-05-2003 15:39
Stream info for
G:\capture\Art_Attack_2003_March_05_15_00.mpg
VIDEO: Resolution 480 x 576
(2/3 D1)
Aspect ratio is 4:3
Frame rate 25.00 fps
Nominal bitrate 15000000 bps
first PTS: 00:00:00.280
AUDIO: MPEG-1, Layer 2
48.0 kHz, Stereo
Bitrate 192 kbps
Frame Length 24.0 ms (576 bytes)
first PTS: 00:00:00.180
Audio starts 99 ms early
(->video delay on muxing)
==MAKING PVA==
Input: G:\capture\Art_Attack_2003_March_05_15_00.mpg
PVA: \Art_Attack_2003_March_05_15_00.mpg.pva
FIXING startup delay.
FIXING stream synch.
ADJUSTING GOP timecodes.
Syncing: Cutting audio.
ALERT> PTS less than NofP (640 ms < 680 ms) at 00:00:00.000
No integer frame match for A/V.
ALERT> Doubling of temporal offset 1
ALERT> Temporal structure wrong in GOP - dropping
[ Found a GOP with more than 15 pics.
See summary for total number at end. ]
ALERT> video frame missing at 00:00:29.200
ALERT> PTS less than NofP (400 ms < 440 ms) at 00:00:00.000
ALERT> Doubling of temporal offset 0
ALERT> 15 video frames missing at 00:05:46.120
Syncing: Cutting video.
ALERT> PTS less than NofP (480 ms < 600 ms) at 00:07:45.280
17 audio frame(s) missing at the end.
Done.
Video bitrate: max 4992 , avg 4189 kbps
Video: 30552 pics 00:20:22.080
Audio: 50920 frames 00:20:22.080
DVD (un)compliance:
152 GOPS with more than 15 frames
3) then I appended two of theese mpg files with PVAcut. I just loaded them sequentially, selected all frames, pressed ADD and repeated with the second. Then I saved the whole stream as pva.
Guest Oliver
Hello!
Just have a look in "Deutsch - Probleme mit: PVA, PVACut, TMPGEnc". You should try to disable "calculate new PTS" in PVACut, but it is explained in the "deutsch"-part in greater detail.
Bye, Oliver
Thx. I will read that !
