madface Posted June 21, 2006 Posted June 21, 2006 (edited) HiHo, in previous version dvbserver startet (for streaming in my home net) and with even server stártet i could view. now, since 3.5, if the server is startet and connceted, DVBViewer founds no hardware. if i stop the server, DVBViewer works but the server can't be started anymore. am i doin something wrong, or cannot work these two together anymore. hardware is terratec 1400 dvb-t with drivers. 5.0.17 regards face Edited June 21, 2006 by madface Quote
Guest Lars_MQ Posted June 21, 2006 Posted June 21, 2006 No in earlier versions the DVBServer was simply deactivated when DVBViewer was startet.. This is not done anymore, because of the multiinstancing and multicard feature. Now you have to take care to stop the server if you need the hardware for the DVBViewer, or you could put a second DVB Card into the computer and run both programs at the same time Quote
madface Posted June 21, 2006 Author Posted June 21, 2006 thanx for fast answer, isnt good for my purpose but i can live with that! go on, DVBViewer is growing finer and finer! Quote
