sbrownuk1 Posted June 24, 2006 Posted June 24, 2006 hi after a week of trying i cannot get any audio on BBCHD , can some help. i am using the beta version of dvbveiwer. Quote
Geheee Posted June 24, 2006 Posted June 24, 2006 hi after a week of trying i cannot get any audio on BBCHD , can some help.i am using the beta version of dvbveiwer. BBC HD Audio is in AC3 format. If you can get the picture but no audio try and make sure you have an AC3 codec installed on your system. A good free one to try would be AC3filter Quote
sbrownuk1 Posted June 24, 2006 Author Posted June 24, 2006 (edited) ok installed , same with DVBViewer beta, picture nad no sound, BUT DVBViewer pro now has sound and no picture ???????? doing a rescan of 28.2 THANKYOU MY FREIND ALL WORKING NOW Edited June 24, 2006 by sbrownuk1 Quote
