2 questions
DVBFIN
Hi
questions:
1.) How can I use logitech harmony 525 with the DVBViewer? I have tried to put it in MCE remote state, but it isn't working.
2.) When watching TV with DVBViewer, the resolution isn't the same which is TV's native resolution. On short: how do I change the DVBViewer's viewing resolution? (now in every corner there are empty space....)
specs:
-Hauppauge HVR1100(also infrared receiver)
-DFI infinity RS482 motherboard
-logitech harmony 525 remote controller
Guest Oliver
1. You need a tool like WinLIRC or Girder.
2. You can't, it's DVB. The possible resolutions are limited by the graphics card driver.
1.) is it still enough to have just hauppauge's own ir receiver with those porgrams?
2.) Is there any other way to resize the picture to "full screen"?
please use the zoom settings
Settings -> Zoom... -> Pan & Scan
now drop the slider to right side
