Better handling of Dual Channel sound
Puppy
There is no diffrence in handling Stereo and Dual Channel sound, even the same icon is displayed in statusbar. I'd like to have different icon for Dual Channel and ability to select original, dubbing or both sound channels where selecting original or dubbing means that the single channel sound goes to both Left and Right audio channel outputs. Currently I can only disable left or right channel which is not sufficient.
Download the RadLight Audio Selection Filter from the memberes area, plugins section. Put it into the DVBViewer\Filters folder and register it with the RadLight Filter Manager (also available in the members area). After that, selecting the right or left channel in DVBViewer will output it to both speakers.
