udalkiran Posted July 1, 2006 Posted July 1, 2006 new version is very good and very fast but there is a problem with favourite channels list. it doesn't work correctly. when i click on a channel on list, it shows another one. i've noticed this in beta version too. but not in ver. 3.2.6. my satellite turksat 2/a Quote
Guest Lars_MQ Posted July 1, 2006 Posted July 1, 2006 Please elaborate. Your up to now the only one reporting this problem. Quote
zyadas Posted July 2, 2006 Posted July 2, 2006 (edited) new version is very good and very fastbut there is a problem with favourite channels list. it doesn't work correctly. when i click on a channel on list, it shows another one. i've noticed this in beta version too. but not in ver. 3.2.6. my satellite turksat 2/a in the same way.... Edited July 2, 2006 by zyadas Quote
osmanoca Posted July 11, 2006 Posted July 11, 2006 Not reproduceable. Dear Lars and others. please understand creating turksat favorite list problem. many friend wirted in forum that when we try to create a favorite list while moving a channel it changes with another channel. after moving a channel to favorite list some channels replace with some other channels. so when we click to watch a channel for example "channel one", DVBViewer shows "channel 5" in screen. and this is a very big problem. this problem was in progdvb too. but now this problem is in latest version of DVBViewer. this is the worst problem for us. we cant use latest DVBViewer because of this problem. please try to solve this bug. this is a bug really. we use as usual and we saw this problem only in this latest version. we are waiting for a real solve. you have to try in turksat to see this problem if right or not. Quote
Guest Lars_MQ Posted July 11, 2006 Posted July 11, 2006 Well no bug in the DVBViewer for sure. It must be a problem with the channels from the sat you use. Can't reproduced it, have no clue what would cause it. please provide a channels.dat and a favourites.xml so we can see what they do wrong and if we can do something about it. Does it happen with the DVBViewer GE also? Please test. As long as you can't provide the above said infos and data, we can't and won't do anything. Quote
osmanoca Posted July 11, 2006 Posted July 11, 2006 Well no bug in the DVBViewer for sure. It must be a problem with the channels from the sat you use. Can't reproduced it, have no clue what would cause it. please provide a channels.dat and a favourites.xml so we can see what they do wrong and if we can do something about it. Does it happen with the DVBViewer GE also? Please test. As long as you can't provide the above said infos and data, we can't and won't do anything. i will send you favorite and channels files. but DVBViewer GE is an old version and this problem is only in this DVBViewer 3.5.0 version. i will try in GE edition too. Quote
osmanoca Posted July 11, 2006 Posted July 11, 2006 hi dear Lars. i sent you favorite list , channel list and support tool files. i only clicked on these 5 channels and added to favorites. there are these channels in favorites: atv star kanal 1 samanyolu.tv show tv (this channel appears in all channels from favorite list) when i click on these channels from channel list there is no any problem but when i click from favorites all of them play "show tv" channel. so we mean this problem. this problem is changing in ever time. everytime when i scan channels and create favorite list, the problem channel is different everytime. please see these problem... favorite_channel.rar support.zip Quote
Saigon Posted July 12, 2006 Posted July 12, 2006 I don't know if this is related but decided to post my experiences with favourite channels. After installing latest pro version i scanned channels and tried immediately after that to create a favourite list. This was not possible since it did not allow to do anything in the editor. After restarting DVBViewer it was now possible to add channels to favourite list. But then I discovered that selecting a channel from the left pane and pressing the plus-button, which i assume inserts the channel into favourite list, added only the channel that the program was tuned to, not the one I had selected. (In one of the betaversions this manifested so that the channel name was different, but everything else was from the channel that was tuned.) That way I was forced to tune into a channel and go to channel editor, favourites list, and press the plus-button, exit all editors and tune into different channel. Over and over again. Only after I had done all this for all channels I wanted into favourites list, did I discover that you can drag and drop channels from the left pane. Anyway, the problems mentioned here may be related, or yours might be just because weird transmitter configurations and the way DVBViewer pro selects the channels. I could also mention that in beta versions I managed to add a channel into favourite list that DVBViewer couldn't tune into, it just gave "Hardware not available" message. Creating new channels list and favourite list solved this problem. Quote
osmanoca Posted July 13, 2006 Posted July 13, 2006 Dear LARS ans HACKBART everybody writes about this favorite list creating problem in turkey forums. please think all watchers and try to solve this problem and write here somethings about your works on this subject. all turksat watchers are waiting for a solution. Quote
udalkiran Posted July 15, 2006 Author Posted July 15, 2006 problem problem problem turksat 2a favorite chaneel problemmmmmmmmmm i will mad !!!!!!!!1 Quote
Mehmet Birol Posted July 15, 2006 Posted July 15, 2006 problem problem problem turksat 2a favorite chaneel problemmmmmmmmmm i will mad !!!!!!!!1 Yes problem turksat 2A favorite channel Quote
Guest Lars_MQ Posted July 15, 2006 Posted July 15, 2006 all turksat watchers are waiting for a solution. Don't use favorites for turksat channels. sort your channellist. Quote
osmanoca Posted July 16, 2006 Posted July 16, 2006 Don't use favorites for turksat channels. sort your channellist. Dear Lars_MQ We are doing so but this is a problem and we will wait you to solve this problem. You could say that "use channel list until we solve for fix this problem. we will solve it soon." this answer is better for us dear mr Lars. you cant imagine that how everybody is sad and angry for this problem. because DVBViewer users payed money for this program and if they ask help about a problem this must be so. it is their right. so please when you answer explain well to inform us good about your position on this subject. we hope you mean that you will fix this problem soon and until you fix this problem we will use channel list. thanks and waiting a new fixed version soon specially for this problem.. Quote
interlude Posted July 16, 2006 Posted July 16, 2006 Hi, I've got same (so big) problem! When ı copy my old favorit list in 3.5.0 beta evrything is ok!But when ı use favori list evry thing is wrong on Turksat channel!!! I create a new favorit list but same problem is go on in Turksat favori channel!! Please solve this problem!We're (Tutksat users) so aggrieved!Turksat is very problematic satellite! Best regards,more power to your elbow... Quote
udalkiran Posted July 16, 2006 Author Posted July 16, 2006 Hi,I've got same (so big) problem! When ı copy my old favorit list in 3.5.0 beta evrything is ok!But when ı use favori list evry thing is wrong on Turksat channel!!! I create a new favorit list but same problem is go on in Turksat favori channel!! Please solve this problem!We're (Tutksat users) so aggrieved!Turksat is very problematic satellite! Best regards,more power to your elbow... exactly !!!!! please dear hackbart i want new version Quote
interlude Posted July 17, 2006 Posted July 17, 2006 Please,please,please dear hackbart new version!!! We want new version! Best regards.... Quote
Mehmet Birol Posted July 17, 2006 Posted July 17, 2006 Please,please,please dear hackbart new version!!!We want new version! Best regards.... this favorite problem Quote
udalkiran Posted July 18, 2006 Author Posted July 18, 2006 (edited) i am read readme file but this problem continue Edited July 18, 2006 by udalkiran Quote
interlude Posted July 18, 2006 Posted July 18, 2006 i am read readme filebut this problem continue Perhaps it go on!Because dear Hackbart doesn't solve our problem! We want a new version but there isn't any evolution! We can't create Turksat favorit list!!! Please,please new version!!! Best regards... Quote
udalkiran Posted July 19, 2006 Author Posted July 19, 2006 (edited) new version is very good and very fastbut there is a problem with favourite channels list. it doesn't work correctly. when i click on a channel on list, it shows another one. i've noticed this in beta version too. but not in ver. 3.2.6. my satellite turksat 2/a dear hackbart and lars mq I bought your programme and I have not any problem up to the present about it but in the last version ,favorite channel problems and your unconcerning has annoyed me and all users in Turkey please find a way for this proplem more Turkish users are aggrived Our Turkish people have been boosting your programme at the biggest forum of Turkey www.********.com here is satellite forums and in this forum we have 250000 users in this forum we do not want to be slander your programme by other people and we desire to work out the problem and adjust it urgently there are no problem in hotbird and astra only problem in Turksat the reason of problem in the Turksat satellite the SYMBOL RATES are very low we are looking forward to hearing soon best regards ......... Edited July 20, 2006 by hackbart Quote
hackbart Posted July 20, 2006 Posted July 20, 2006 Woha, calm down. We have already fixed this issue, and it wont appear in the next version. But honestly i wonder if there are 250 000 turkish users who might use the DVBViewer why i have less than 1/1000 turkish users in my legal customer database? Do not wonder why i edited the url to your board. According to german laws it is probihibed to offer some stuff you share in the board and it also violates our forum rules. Christian Quote
udalkiran Posted July 20, 2006 Author Posted July 20, 2006 (edited) Woha, calm down. We have already fixed this issue, and it wont appear in the next version. But honestly i wonder if there are 250 000 turkish users who might use the DVBViewer why i have less than 1/1000 turkish users in my legal customer database? Do not wonder why i edited the url to your board. According to german laws it is probihibed to offer some stuff you share in the board and it also violates our forum rules. Christian excuseme for url there are onLy 250 000 users in this a forum All of this amount of this users not use this programme :D Edited July 20, 2006 by udalkiran Quote
coreduo Posted July 20, 2006 Posted July 20, 2006 (edited) Woha, calm down. We have already fixed this issue, and it wont appear in the next version. But honestly i wonder if there are 250 000 turkish users who might use the DVBViewer why i have less than 1/1000 turkish users in my legal customer database? Do not wonder why i edited the url to your board. According to german laws it is probihibed to offer some stuff you share in the board and it also violates our forum rules. Christian thanks christian i am registered turkish user i am waiting fixed version Edited July 20, 2006 by coreduo Quote
udalkiran Posted August 7, 2006 Author Posted August 7, 2006 dear hackbart lars mq and others very very thanks for new update Quote
