antdude Posted July 1, 2006 Posted July 1, 2006 Hi all, I noticed v3.5.0 final is out from http://www.DVBViewer.com/members/ ... » Description: DVBViewer ( 64375 Downloads ) » Version: V3.5.0 » Size: 6378 KBytes » Last Updated: 18.06.06 I installed it over my old Pro beta, but now I get "No hardware available!" error. I checked the settings (Air2PC-ATSC-PCI device) in options, and they appear to be OK. Are you guys getting this? Where can I get the older beta that worked before I upgraded? My TE version still works too, Thank you in advance. Quote
antdude Posted July 1, 2006 Author Posted July 1, 2006 (edited) try a manual hardware scan."Scan Devices" button doesn't seem to do anything. I got no feedback on errors or anything. Edited July 1, 2006 by antdude Quote
Guest Lars_MQ Posted July 1, 2006 Posted July 1, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
antdude Posted July 1, 2006 Author Posted July 1, 2006 (edited) Please post some more information:http://www.DVBViewer.com/forum/index.php?showtopic=2210 Here you go... support.zip (also attached a copy of the ATSC channel lists). I also tried something. I imported my saved/exported channel list INI and that SORT of worked! However, some channels were blank (black or gray screen) with audio. At least I got rid of the error message about hardware not found. Odd. So, I tried clearing my channel list, exited DVBViewer Pro, and relaunch it. No errors. So, I tried scanning for channels. It found the channels. I checked them, but some of them are still blank (black or gray) with audio. And yes, I checked my signal strengths (green and high numbers). I check TE version to be sure that still works, and they do (using the same channel list). Edited July 1, 2006 by antdude Quote
antdude Posted July 1, 2006 Author Posted July 1, 2006 Ooops, I think I posted this in the wrong forum. It should be in English one. Please move it if it is the wrong place. Thanks in advance. Quote
antdude Posted July 4, 2006 Author Posted July 4, 2006 Here you go... support.zip (also attached a copy of the ATSC channel lists). I also tried something. I imported my saved/exported channel list INI and that SORT of worked! However, some channels were blank (black or gray screen) with audio. At least I got rid of the error message about hardware not found. Odd. So, I tried clearing my channel list, exited DVBViewer Pro, and relaunch it. No errors. So, I tried scanning for channels. It found the channels. I checked them, but some of them are still blank (black or gray) with audio. And yes, I checked my signal strengths (green and high numbers). I check TE version to be sure that still works, and they do (using the same channel list). I found out that I can't use Auto and Sonic's decoder for video display, so I tried Interdev's WinDVD decoder. That worked. Quote
