Dragonslore Posted July 4, 2006 Posted July 4, 2006 Hi there, I'm a guy from France. First of all, thank you very much for all help you provide on this website. I tried DVBViewer and it corresponds to my needs for Sat aspects. I have another card (Winfast DTV2000-H) dedicated to TNT channels (Terrestrial) and I would like to know if there is any possibility to configure it in addition of my SS2 to regroup all TV aspects in only one software. Thank you very much in advance, Pierre-Manu Quote
Guest Lars_MQ Posted July 4, 2006 Posted July 4, 2006 The digital Part of this card schould work, since there is a BDA driver. The analogue part won't work with the DVBViewer. Quote
Dragonslore Posted July 4, 2006 Author Posted July 4, 2006 Thank you for your quick answer ! Can you confirm to me that in this case I'll be able to receive Sat channels and Numeric TNT channels simultanely in DVBViewer ? Quote
Guest Lars_MQ Posted July 4, 2006 Posted July 4, 2006 I can confirm, that the DVBViewer is capable of working with DVB-S and DVB-T devices the same time. I don't know what numeric TNT channels are and I won't give any guarantie. All I can say is: the DVBViewer works with BDA drivers, as long as the hardware/driver manufacturer of this card follow the specs, the viewer should work with this card (remember only digital (DVB)channels, no analogue channels!). Never tested the card, maybe some user has experience with it. Quote
Dragonslore Posted July 5, 2006 Author Posted July 5, 2006 Thank you very much for all ! I'm doing some tests, I hope everything will work perfectly since tomorrow ! Quote
