Guest Michael Posted March 10, 2003 Posted March 10, 2003 It would be cool if you could implement the DVBControl Plugin support.... like in DVBPortal.... then i would be able to use the megaradio.mp3 plugin and some others :-) Quote
Guest hackbart Posted March 11, 2003 Posted March 11, 2003 well i already read the radiomp3 data out of the teletext stream - at least i think i do so Since i only receive Astra 19.2° yet, i'm unable to test the dump function, but after the diseqc switch is installed i will definitively publish that thing.. Christian Quote
Guest Michael Posted March 11, 2003 Posted March 11, 2003 well i already read the radiomp3 data out of the teletext stream - at least i think i do so Since i only receive Astra 19.2° yet, i'm unable to test the dump function, but after the diseqc switch is installed i will definitively publish that thing.. Christian i hope it will be able to play the braodcased stream directly.... the other r.mp3 plugin can't and some bitrate filter.... cause not everything is send in 128kbps... / 44khz and some filter if encrypted songs are send... and some filter for filenames ( like Megaradio Live or Advertisement... ) ID3Tag would be cool btw... for all who use the plugin.... you can set VPID=0 and APID=0 and then you can record with 1% cpu power mp3's Quote
fesche Posted March 13, 2003 Posted March 13, 2003 Salut Micha ! on what Sattelite is this megaradio on ? Hotbird ? Quote
Guest Michael Posted March 18, 2003 Posted March 18, 2003 yes it is braodcasted througt NBC Giga teletext as MP3 but you can receive it as radio too.... on astra is think.... Quote
