EPG from XMLTV
Pangel
I have just bought DVBVierver 3.5 and I think it is a great!
I have one question: Is it possible to import EPG-informations from a XML-file?
I'm asking because my provider is only sending EPG-information for the playing show and the next one.
This makes it hard to setup recording of a show tomorrow. :)
Thanks.
/Pangel
If you havent already found it, there is an xmltv importer in the beta section of the members area. Works fine for me except for some timezone related glitch - I live in CET TZ and if I import UK listings they are offset by an hour. Might just be the way I've set it up though. I haven't spent much time digging since I can make it work by setting my system TZ to the UK just before importing and resetting it afterwards - easy enough for now.
Thanks for the information brightside.
I will test it this weekend.
/Pangel
