DVBViewer with lirc server on linux
Habos
Hi
I have a vdr box with ss1 and with lirc working nice with my remote control. Unfortunatly winlirc dosn't support my remote receiver. My remote has multi functions for 4 devices and I like to use 1 of it for DVBViewer that is runing on my XP box. I would like to know if I can setup DVBViewer to use the lirc server that is runing on my linux machine. Both PC's runing in same network, so I probably only need to put in somwhere the IP from the PC runing lirc but I was unable to found where should I enter that.
Thx
Hi
Unfortunatly I didn't get an answer. I still think it is possible just need to know where to put the IP of my lirc server instead of 127.0.0.1
I searched over the config files but couldn't find such option, please can you give me some hint.
Thx
I don't think so... with every probability is hardcoded in the app, and IMHO is absolutely uncommon to "remotize" a remote control... ;)
What do you mean with "dosn't support"? ;)
As stated here in the bottom line:
"Remote control configuration files (lirc.conf, sample.cf, etc.) are identical and interchangable"...
Have you already tried to use, at least, the linux .conf file with winlirc???
Edited by Gioxy
It's maybe uncommon but it can happen as I have on one machine a linux system with VDR and SS1 working and also my remote control works without any problem on that system.
On other system I have windows with SS2 and DVBViewer.
The winlirc dosn't recognise my IR device as it's a custom build serial device (Igor Cesko's serial remote interface)
Becouse my remote works on linux with lirc without any problem, and becouse my remote is a multifunction device (4 devices) i would like to use it also to control the DVBViewer with it (i don't want to buy another remote device and IR interface just for windows) and I already setup foobar that way.
IMHO the simplest and fastest solution is to build/buy another Igor Cesko's serial remote interface for your windows PC and make it working; I also maked one of it, and work perfectly; moreover you already had the config's files...
However you can trust in our helping hand to try to resolve your difficulty, until you post a specific and well described problem... :)
I told you this way only because I do belive that Winlirc input parameters are hardcoded, and it's honestly too difficult that DVBViewer programmers want to add this function for one people only... but, if you prefer, you can claim for a more "official reply"... ;)
Edited by Gioxy
  • 1 month later...
you are wrong :) 2 people were lookin for this feature...
it is done and yes there it is :bye:
look here WinLIRC
Phr³³k
Edited by Phr³³k
Ohhh, I saw... :)
...in that case I'm very happy to having been wrong, above all for you and for all people with such need... :bye:
Edited by Gioxy
