boborg Posted July 11, 2006 Posted July 11, 2006 (edited) Any chance that you might provide an option to save epg to multiple xml files so each channel gets its on file? Instead of the one file with them all in one like is possible now from the EPG window save EGP option. Edited July 11, 2006 by boborg Quote
Guest Lars_MQ Posted July 11, 2006 Posted July 11, 2006 Any chance that you might provide an option to save epg to multiple xml files so each channel gets its on file? No, no need for it, cause you can do it yourself. Use the COM-Interface. Or if you can't do it yourself find someone who has the time and need for this. Quote
