DVBW 3.5 problem with Cyberlink
I have problem with codek from powerdvd 7 (cyberlink) and WRM9 on before version of dvbwiever was ok now like attachments
Please
i use the reg file then restart but no effect for me
Not leave audio codec on <auto>, adjust one tightly!
now its everything working ok thnx
I've exactly the same problem with powerdvd7 codecs and 3.5.0.1 :bye: They work well with 3.2.6...
I managed to make it working a few seconds while tuning the zoom ratio and clicking on default button but now it doesn't work.
I tried a clean install of 3.5.0.1 but with no result...
[EDIT]
I'm not the same with that problem...
http://www.DVBViewer.com/forum/index.php?s...=11555&st=0
Edited by Quenotte
Try AC3Filter as an audio decoder.
Which WinTV card do you have?
I tried it with no change
I have a HVR-1300 and an airstar pci and a geforce 6600GT...
Does this happen at the two cards?
Put 'Stop Stream while tuning' on 0 at HVR1300
It happens with the two cards...
I think that it is linked to that: http://www.DVBViewer.com/forum/index.php?showtopic=11555
and http://www.DVBViewer.com/forum/index.php?showtopic=13114
If I disable hardware acceleration the problem disappear...
Do you plan to fix it as it is done in gb-pvr?
Thanks in advance :bye:
Edited by Quenotte
