I can I use my card in a phoenix
wwe
I want to receive Premier world in HD on my pc using DVBViewer, is there anyway i can do this with my own card. [edit]...[/edit]
many thanks
wwe
Guest Oliver
Any tv-card featuring a conditional interface (CI) should support any conditional access module. The DVBViewer Pro is compatible with lots of cards, although many BDA drivers don't support CI.
Here is a list of supported cards:
http://www.DVBViewer.com/forum/index.php?s...c=9117&st=0
You'll find another one here (in German, but that shouldn't matter in case of names). The cards listed in the first part have been tested by CM&V Hackbart, the second part is based on user reports):
http://www.DVBViewer.com/forum/index.php?s...ost&p=69072
Guest Oliver
There is no legal way to do this with a Skystar2 and thus not supported. You need a card with CI.
I have a sky Star 2 with no ci [edit]..[/edit]
wwe
..your question is against the rules. You have to buy a dvb card with CI.
