Streched 544x576 picture with FFDShow
Trifon
Hello,
I havec tested many resize options in FFDshow to avoid streched picture when viewving no DVD format i.e. 544x576.
Can someone help me to get the right setting?
Thanks.
Try (at least also) to search/ask in the ffdshow forum...
Thanks Gioxy, unfortunatly that won't help as DVB applications are quite spécific.
For instance ProgDVB has no problem as it works like a file player.
With MyTHeatre, one have to restart the graph to get the right aspect ratio with thosde peculiars no DVD format chanels.
This looks not available with DVBViewver.
Found it! Just forgotten to check "resize allways" in "resize"
