Mortten Posted July 21, 2006 Posted July 21, 2006 I think that DVBViewer is a fantastic piece of software as a PVR. But there is no way I could install it into my living room as an HTPC application. And that is because of the OSD. What I need is a HTPC UI similar to MCE (or Meedio, or MediaPortal...) which is intuitive, good looking and not a mix of my choice of language and German. And would be suitable for 16:9 screen. Yes, I know there is a OSD skin editor. But for me it is not a very good option because I simply cannot comprehend the amount of (undocumented) information and elements that is needed in various parts of the OSD. Quote
dgdg Posted July 21, 2006 Posted July 21, 2006 (edited) Hi Mortten, same problem her. I was very happy about the OSD (I didn't expect this feature because I used ProgDVB before). So I made the living room test together with the family. But this was not very successfull It's not only the language mix (I did not have that problem because I used it in German). It's the whole structure and the key assignments. Their are some basics that have to be considered if you design a intuitive user interface. Non of them was considered in the DVBViewer OSD The OSD may be ok for experts that use it every evening for some hours and than after 4 weeks know how to handle all the different key assignments in all the differents dialogs (I guess their are not to dialogs with the same key assignment ). I had a look at the skin editor, but I think it will not fix the problem. Because you can only redefine existing pages and dialogs - to many things are hardcoded. Maybe the confusing key assignments can be fixed and the language problem - but that's only half the battle. So I sadly switched back to Pinnacle Media Center, which is slow and causes a lot of trouble - but it's easy. Another good example (looks very similar to Pinnacle) is the software, that comes with the Freecom DVB-T stick. I don't know the Windows Media Center, but I think it follows the same philosophy. Propably it was used as draft for all the others - except for DVBViewer But from technical point of view DVBViewer it's an exellent software. regards dgdg Edited July 21, 2006 by dgdg Quote
