SweMart Posted July 24, 2006 Posted July 24, 2006 Hi, I'm using 3.5 with the Nvidia PureVideo codecs for audio and video. I'm having problems with the stretch function with certain channels, all channels except the Canal+ channels are shown in 16:9 but they only occupy approx 70% of my LCD TV. The Canal+ channels stretch ok so that they cover the entire screen. I'm not having this problem in MCE, MP or myTheatre. Is there some setting to fix this? I've tried 16:9 and Auto as aspect ratios with no luck. The problem can be solved after switching channel by setting the aspect ratio using the OSD settings menu but as soon as I switch channel I have to redo the entire procedure. Many thanks, Martin Quote
