Http-Webserver on DC Windows Server 2003 R2
jodoxp
Hello,
I have installed the DVBViewer 3.5 on my (private) Windows Server 2003 R2 and it works fine. Also the Http-Server Beta worked. Now I added some roles to my server, especially the terminal service, IIS and the ADS.
Since then I can not open the start page. I now downloaded the Http-Server 1.0 Final, entered my IP and port (79) as described in the readme-file.
Same error: Page can not be displayed. Any idea if there is something blocked or whatever ...
Edited by jodoxp
  • 1 month later...
Hello,
Ho,
did you check the firewall settings or the port number used by server and iis (are they on same port)?
