Multithreading - any known issues ?
gibman
Before I pull the trigger on a new AMD 64 X2 CPU I would like to know if DVBViewer is multithreaded or not.
And if any known problems exist when running with multiple CPUs.
/Gibman
Edited by gibman
Guest Lars_MQ
Some Parts of the DVBViewer are multithreaded. But that are only minor things. Most important ist the DirectShow framework of windows which will be multithreaded (in some parts at least I think -> decoder if it supports it). But you have always the possibility to bind the DVBViewer main (and sidethreads) to one CPU in the options.
No problems with a Pentium 4 Hyperthreating 3 Ghz.
mfg Steffen
no problems with Intel Pentium D 940 too :(
the DVBViewer use both cores, if you haven't select the option "Use Only First CPU"
:bye:
