ThomP Posted August 2, 2006 Posted August 2, 2006 I just installed DVBViewer for use with my Nova-t-500. So far it looks very promising - it might end up replacing Meedio as my HTPC software - but missing support for the Hauppauge remote is a major disadvantage. I know I could use Girder, but it's expensive, it's complex to setup and it's resource demanding, so could you please add native/plugin support for the Hauppauge remote? Quote
ThomP Posted August 3, 2006 Author Posted August 3, 2006 I just installed DVBViewer for use with my Nova-t-500. So far it looks very promising - it might end up replacing Meedio as my HTPC software - but missing support for the Hauppauge remote is a major disadvantage. I know I could use Girder, but it's expensive, it's complex to setup and it's resource demanding, so could you please add native/plugin support for the Hauppauge remote? Please excuse my ignorance! I just learned that the Hauppauge remote emulates keystrokes and therefore should work with DVBViewer. Sorry. Quote
