antdude Posted August 14, 2006 Posted August 14, 2006 Is anyone having problems getting no voices/dialogs from TV shows using Dolby Digital (5.1) with AC3 Filter v1.09a from K-Lite Codec Full Pack v2.74 (http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm)? I have a 4.1 speaker setup with my Audigy 2 ZS. Input format: AC3 - 48000 User format: PCM24 2/2.1 (4.1) 0 Output format: PCM24 2/2.1 (4.1) 48000 Decoding chain: (AC3 - 48000) -> Decoder -> (Linear PCM 3/2.1 (5.1) 48000) -> Processor -> (PCM24 2/2.1 (4.1) 48000) -> Dejitter -> (PCM24 2/2.1 (4.1) 48000) Filters info (in order of processing): Decoder: AC3 speakers: 3/2.1 (5.1) sample rate: 48000Hz bitrate: 384kbps stream: 8 bit frame size: 1536 bytes nsamples: 1536 bsid: 6 clev: -3.0dB (0.7071) slev: -3.0dB (0.7071) dialnorm: -22dB bandwidth: 10kHz/18kHz Processor: (Linear PCM 3/2.1 (5.1) 48000) -> Input levels -> (Linear PCM 3/2.1 (5.1) 48000) -> Mixer -> (Linear PCM 2/2.1 (4.1) 48000) -> Bass redirection -> (Linear PCM 2/2.1 (4.1) 48000) -> AGC -> (Linear PCM 2/2.1 (4.1) 48000) -> Delay -> (Linear PCM 2/2.1 (4.1) 48000) -> Output levels -> (Linear PCM 2/2.1 (4.1) 48000) -> Linear->PCM converter -> (PCM24 2/2.1 (4.1) 48000) Dejitter: - My Windows speaker's setup is set up as Quadraphonic. Thank you in advance. Quote
antdude Posted August 14, 2006 Author Posted August 14, 2006 Hmm, it seems like an installation from stand alone AC3 Filter v1.09a fixed it. Hmm, I probably have two AC3 Filter installations now. I will clean up the mess when I have to install K-Lite Codec again. I also noticed Media Player Classic had problems playing my TS and MPEG files with the AC3 Filter. Quote
