nigelbb Posted August 15, 2006 Posted August 15, 2006 I have just received my Technotrend S2-3200 card & am now able to receive DVB-S2 stations such as ProSeiben HD & Sat 1 HD. When I use DVBServer to stream over my LAN to other PCs it works great for all DVB-S channels both MPEG2 & H.264. However when I try & switch to one of the DVB-S2 channels then nothing is broadcast & the bit rate on the DVBServer main screen drops to zero. Is this a known problem? Cheers Nigel Quote
Guest Lars_MQ Posted August 15, 2006 Posted August 15, 2006 This is to be expected, cause the dvbserver doesn't support dvbs-2 until now. As soon as there is stable support verified dvbs-2 cards (or me having a need for dvbs-2 what ever comes first) there will be an update. Quote
nigelbb Posted August 17, 2006 Author Posted August 17, 2006 This is to be expected, cause the dvbserver doesn't support dvbs-2 until now. As soon as there is stable support verified dvbs-2 cards (or me having a need for dvbs-2 what ever comes first) there will be an update. Thanks Lars. Glad that it wasn't something that I was doing wrong:-) I just hope that you get DVB-S2 support into DVBServer before BBC HD moves to DVB-S2. Cheers Nigel Quote
Derrick Posted August 24, 2006 Posted August 24, 2006 ..just a reminder: please upgrade the dvbserver to dvb-s2 The real reason for this post is, that I don't know and can't find how to scan or import dvb-s2 transponders into the pro_channellist. Import from transedit doesn't work. I thought that @Griga had already explained how to proceed. ps. mea culpa I've overlooked the pro_beta in the member's area Quote
