lout Posted August 18, 2006 Posted August 18, 2006 (edited) DVBViewer working with TechniSat Multytenne?... its antene with 4LNB DiSEqC Edited August 18, 2006 by lout Quote
Griga Posted August 18, 2006 Posted August 18, 2006 Sure it does. I bought it 3 months ago, works like a charm. However, make sure that DVBViewer supports DiSEqC with your DVB-S card. Which one will be used? And please note, that the Multytenne is designed for Germany or near by - the LNBs are adjusted accordingly, and you can't change it. Quote
lout Posted August 18, 2006 Author Posted August 18, 2006 (edited) Sure it does. I bought it 3 months ago, works like a charm. However, make sure that DVBViewer supports DiSEqC with you DVB-S card. Which one will be used? And please note, that the Multytenne is designed for Germany or near by - the LNBs are adjusted accordingly, and you can't change it. I live in Prague its close to Germany... now i will use with ss2 and next week i hope come technotrend dvb-s2 3200 hdtv... Where i found if DVBViewer supports DiSEqC with this cards? Edited August 18, 2006 by lout Quote
Griga Posted August 18, 2006 Posted August 18, 2006 (edited) DVBViewer supports DiSEqC with both cards. P.S.: It works at least with SS2 hardware rev. 2.6. With the old rev 2.3 I had some difficulties. It's known for its DiSEqC issues. Edited August 18, 2006 by Griga Quote
