McenterFreak Posted August 20, 2006 Posted August 20, 2006 I can't get scheduling a recording to work. In options>Extended there is an option to use "Microsoft Task Scheduler" but it is grayed out When i try to schedule a recording, nothing happens. I use DVBViewer>EPG Window>Send to PVR Quote
Guest Oliver Posted August 20, 2006 Posted August 20, 2006 http://www.DVBViewer.com/oliver/recording....nameddest=timer The Scheduler is to be used for reactivating from hibernation or stand-by. You need to download the "DVB task scheduler" from the service center and put it in the DVBViewer folder. Then you can activate the function in the options. Quote
wheelie Posted August 21, 2006 Posted August 21, 2006 Is there anyway to automatically start scheduler.exe when DVBViewer starts or I schedule a recording? Other than using MS Task Scheduler i can't find a way. At the moment I have to manually start DVD Task Scheduler for it to work. cheers Quote
Guest Oliver Posted August 21, 2006 Posted August 21, 2006 When put into the DVBViewer folder it will always start automatically. Please refer to the scheduler's readme. Quote
wheelie Posted August 23, 2006 Posted August 23, 2006 (edited) Thanks, I've managed to get it working now. cheers Edited August 23, 2006 by wheelie Quote
