Multiple cards
Exel
Can I run DVBViewer smoothly with two DVB PCI cards from different manufacturers or even different type receiver types? For example other card being TechniSat DVB-C and another being Twinhan DVB-T?
If I start recording a program with one of the tuners and change channel to a different mux, does DVBViewer automatically use the other card to tune the channel?
I currently have a single Cablestar in my computer and I'm looking at getting a second tuner. I wouldn't want to get another Technisat card because of the poor remote, so another manufacturer's card that would come with a better remote would be nice if they worked well together with DVBV.
Thanks.
Hello,
here is a list of hardware the will work with installted bda driver.
http://www.steffen-klausing.de/content4/fa...&artlang=de
yes, that is correct.
:bye:
If I remember it right the automatic change works only by the same type of cards dvbs>dvbs or dvbt>dvbt but no dvbs>dvbt.
