derevo Posted August 21, 2006 Posted August 21, 2006 does it support TerraTec Cinergy 2400i dual tuner card?? Quote
hdv Posted August 21, 2006 Posted August 21, 2006 Hello, here you can find hardware that work with DVBViewer, working hardware with the BDA (MCE) driver with the tool Transedit MMC you can check your hardware if you can find channels, the DVBViewer will work use the transponderlist, Terrestrial (EUR) Quote
Benson Posted August 21, 2006 Posted August 21, 2006 It will work. The card is a good choice for a nice DVBViewer multituner system. Quote
Isidar Posted August 21, 2006 Posted August 21, 2006 Hi YES!!! it definitely works, with it ... and very good, too ... even together with other cards, have fun Isidar Quote
