Klausing Posted March 19, 2003 Posted March 19, 2003 Can we have a little mark/hook in the recorder window for recording without AV? It would be nice. So if the record started, AV would be disabled and after the record AV would be enabled automaticly. Its hard to record and stopthe film manualy at the right time with disabled AV. Quote
Guest hackbart Posted March 19, 2003 Posted March 19, 2003 sure, at the moment you can optionally open the recorder window by selecting the menu, right behind the recording button. Christian Quote
Griga Posted March 20, 2003 Posted March 20, 2003 Can we have a little mark/hook in the recorder window for recording without AV? Same request from Oliver here... I would like to see this too. Its hard to record and stop the film manualy at the right time with disabled AV I just had the opportunity to test a "quick shot" from Christian - a version with an additional option to record with audio rendering only. Didn't work perfectly yet, but the CPU usage was very low too - about 1 or 2 percent more compared to completely disabled AV. This would solve the above mentioned problem. Griga Quote
