DVBViewer PRO
Tozo
I'll would like to buy pro version, and I'm from Croatia..is there possibility to buy with american card because there is'nt Croatia listed..if not...what do you suggest?
I have Skysta2 and Airstar2 cards and I noticed that they use same driver .... how pro version handle with this situation ... i saw on demo edition (that came with cards) there is posibility to choose witch card to "load" ... is the same with pro edition?
Also, thus the pro version enable to choose witch codec to use...example..I'll like to use Nvidia Pure codec?
When I'll buy pro edition how is it with updates and future editions?
Thanks!
Hello,
please look here: Purchasing the full version, How to
you can use both devices in one DVBViewer Pro, and you can switch through all channels, and the DVBViewer Pro use the correct card, but you must take a channelscan for every receiving mode
so you can have DVB-S and DVB-T channels in the same channellist
yes, every DirectShow mpeg2 codec is installed the can use with DVBViewer Pro
for more informations please look here: DVBViewer Pro English Manual
every Update is in the future is free, one registration ever DVBViewer Pro :)
