niloju Posted August 24, 2006 Posted August 24, 2006 I think that it would be also good to let DVBViewer to remenber the Aspect ratio and Image Position and Size (Zoom) for each channel in the same way as it works for audio, and better if you could have a check box to select if you want to use this feature or not. Thanks Quote
terssi Posted August 31, 2006 Posted August 31, 2006 A very good idea! Agreed! This would make TV viewing much easier, since you don't have to manually tamper with the settings every time you change the channel. Quote
