Multicast plugin
aa007
Hi!
I have problem with Multicast plugin i want stream all 11 channels wich i have... but when i select 1 channel on multiplex A then in multicast options are only channels that are on multiplex A and i want stream channels on multiplex B too. And when im streaming some channel from multiplex a and i switch to some channel on multiplex B then streaming stops... what can i do?
PS: sorry for my english
Guest Lars_MQ
You can only stream one transponder (Mux). If you want to stream more you need a) for each transponder one card and b. for each card a instance of the dvbserver.
Hello,
you cannot at the same time receive different frequencies with one tuner
you must install a second dvb-card
look on the answer of Lars_MQ
