2 bugs: mosaicpreview & winlirc
patti
Hello, I have noticed two bugs in DVBViewer 3.5.0.1.
1a. using mosaicpreview crashes DVBViewer when I use it with a transponder that has one channel that is not free to air. Mosaicpreview works well if all channels on the transponder are free to air. Version 3.2.6 does not have this bug.
1b. this is not really a bug but mosaicpreview is really sluggish and causes stutter in main picture when compared to 3.2.6 version
2. my homemade winlirc IR-receiver works really well when DVBViewer is not running but as soon as DVBViewer is running winlirc only receives only about 1 out of 20 remote control commands. Winlirc is version 0.6.5. THis problem appears both in 3.2.6 and 3.5.0.1 versions.
Edited by patti
Use the current DVBViewer filter pushsource.ax V 2.8 (Membersarea).
Put the Audio-Renderer on 'Default DirectSound Device'.
Did what you suggested. All of the bugs still remain :( Any other ideas?
