"Shutdown Card" action on a minimized app.
gibman
Hi!
Here is a bug that I think is easy to fix.
Steps to reprod. are as follows.
1) start DVBV, tune into a random channel.
1) Minimize DVBV to systray while channel is still tuned.
2) Using script to send the following line: SendCommand(12327) 'Shutdown Card
3) Restore the DVBV window - No channel tuned, fine-as it should be.
4) Now tune to a random channel.
Now look and behold...
The channel is tuned.
BUT .... No Audio and Video is rendered !!!
DVBsource filter says "no data / connected".
I tried to use the sendcommand on "Enable AudioVideo=16388", no effect.
The only fix is to open the Status window, with the graph etc.
Now click on the dropdown and choose : "audio/video Enabled"
viola, picture and sound again.
Conclusion...do not use the actions.ini command "12327" on a minimized DVBViewer.
/Gibman
