Trifon Posted August 29, 2006 Posted August 29, 2006 My system is: PIC_E MB MB NF4 Twinhan 1030a CAM Aston 1.05. Wondows XP SP2 ATI X1300. I found lot of issues with DVBViewver+Twinhan1030a: DVBViewver hangs after few minutes; shut down then restart the soft is needed 2/3 times per hour, Recording is not possible. Warning window pops up from time to time: "No right to watch this program" I havec tested 2 drivers, the one downloaded from Twinhan website+that that come with the CD. + BDA driver too... So....I am wondering wether DVBViewver3.5 is realy compatible with my DVB card. Any suggestion would be welcome. REgards Quote
Engelbert Posted August 30, 2006 Posted August 30, 2006 Please, the support.zip asked for have left there in the first Thread and poste there. Quote
Derrick Posted August 30, 2006 Posted August 30, 2006 Warning window pops up from time to time: "No right to watch this program" CI-support is not optimal. I have the same module in a FireDTV-S and can watch C+_NL. But from time to time decoding is not possible. There is no reset button for the module !! If I disconnect/reconnect the firedtv from power, the module will be re-initialized. Maybe you can do the same with the reset tool for pci-cards. Otherwise you have to switch to another program with full ci_support (if that exists ). Quote
Trifon Posted August 30, 2006 Author Posted August 30, 2006 CI-support is not optimal. I have the same module in a FireDTV-S and can watch C+_NL. But from time to time decoding is not possible. There is no reset button for the module !! If I disconnect/reconnect the firedtv from power, the module will be re-initialized. Maybe you can do the same with the reset tool for pci-cards. Otherwise you have to switch to another program with full ci_support (if that exists ). Hello, Thanks to all for your answers. I'll send all the requested files to DVBViewver people. May be that will help to improve things. Regards Quote
